cmyk jpegs from lightroom?
rampanthamster
hi all, some photos i've done for someone apparently need to be submitted as cmyk jpegs. How do i go about doing this? I'm just exporting them from lightroom as jpegs but are these cmyk?
I think you will need to load a cmyk profile in your icc profiles folder, then when you export the shot, you choose jpeg then underneath that there is an option for colourspace, you then need to select 'other' and then choose you cmyk profile.
thanks, i'll try that. I actually just manually saved a few in photoshop by changing image mode to cmyk then saving...
Yeah it is a trick thing to do, not sure if it is 100% correct as I think you might need to change them in Photoshop first.
