Terrywoodenpic
- Terry
Rather than use a plate on the bottom with a captured thread and rubber surface.It would probably be stronger and certainly far easier to shape and weld on a layer of plastic, to form a camera plate, to fit a Swiss type QR. It would also have none of the thread stripping or thread insert problems and weaknesses. Ant also no tendency to rotate.
I have done it with a shaped piece of thick brown circuit board material. You can also put a strong fine thread into that material, so it could easily be screwed on for belt and braces security.
But it would be easy to satisfy yourself that your acrylic sheet would be easily strong enough. Dovetail clamping is mostly compression and so is incredibly strong in almost any solid material.
If you really must have a screw mount. You could always fix one in the centre of the Swiss type plate you make.
for the rare occasions you might want to mount that way.
catch
catch2
Too "custom"? ;0)
First assembly
First assembly
First assembly
First assembly - Telephoto
First assembly - Wide Angle
First assembly
First assembly - DIsassembled
First assembly - Rear - Landscape
First assembly - Rear - Portrait
New Hinge and Spring Clip - Open
New Hinge and Spring Clip - Closed
All
Technical Standard Overview
Technical Standard - 75mm Rise
Technical Standard - 25mm Fall
Technical Standard - 45mm Front Tilt
Technical Standard - 45mm Rear Tilt
Technical Standard - 55mm Right Shift
Technical Standard - 45 Degree Right Swing
