- Brian
I have a hot water / heating system that uses water heated by the boiler to heat the cylinder in the airing cupboard, except this morning it didn't!
I thought i'd heard the boiler fire up this morning before i climbed out of my pit......but maybe I was mistaken as it was soon apparent the water was cold when I jumped in the shower
Ive been reading the net and it seems common for the mid position valve to fail, mine is a british gas branded Drayton Ma1 unit.
Before I attack it, I want to be a bit clearer on a couple of things as the water heated up when i had a fiddle with the valve while the controller was set to ON as opposed to it's timed setting.
1. The small lever on the side should rest in W (water) with power off and move with moderate force before returning on it's own to the W position , is this with heating turned off by the controller...or heater electrically isolated (fuse out). Mine's currently living in the M (mid-both) position and refuses to move with moderate force while the programmer is turned off (but still powered)
2. On the end furthest from the wires there's a stubby lever which is referred to by drayton as the lock, what's it's purpose and where should it rest while in normal operation. I know it's not the quick release button because thats adjacent to the W M H lever on the side. It was this Lock lever i fiddled with and when the water was heating I assumed it had freed something off
but not sure if it's actually in the correct position or not now as theres no labelling on the case.
This evening when the timer clicked in for the water to heat up (CH still set to off) the boiler kicked in OK but the rads all around the house were much warmer than usual (the upstairs rads have always been warm to the touch when the water heats but downstairs stayed cold)
Any help is appreciated
Df
Df
