ChrisCW
- Chris
I have found myself in somewhat of a depression surrounding my photography and therefore have almost stopped taking pics. The problem is HDR, or possibly more to the point, my lack of ability to PP and the lack of time to PP.
So I end up doing the same thing each time (workflow..) as it gives me the results I 'think' look best. The problem is that whenever I take a single image and then process that image, I cannot achieve the same 'pop' that I get from bracketting my shots and pushing them through Photomatix.
Whilst I like HDR as I think the dynamic range is more what my eye sees, I think the processing it applies (or I apply) is somewhat artifical (with the halo effect etc). So I am trying different things, although I simply do not have time (or money) to learn something completely new.
As a test I have downloaded a plugin for Lightroom called Enfuse, which I think may give a more realistic image than say Photomatix.
I have attached a number of images below that have either been processed as Tonemapped or Exposure Fusion within Photomatix, or have been produced with Lightroom alone with the Fusion plugin.
If you can look at the pics, they maybe slightly different in crop etc, but its the processing I am having issues with (mainly!) and let me know which you think is best and any suggestions as to quick and easy (ish) solutions to my woes it would be appreciated:
Firstly this was my image I posted as a final (originally) This was produced with Photomatix (3 image Tonemapped), then levels/crop/sharpening in Lightroom (LR) and then finally into Irfanfiew for the canvas size adjust (black surround):
1.
Alyn_Caergwrle3 by Chris (aka Seedubs), on Flickr
Original (1)
The second image was produced using Photomatix (2 image Exposure Fusion) then levels/crop/sharpening in Lightroom (LR) and then finally into Irfanfiew for the canvas size adjust (black surround):
2.
2 Picture fuse1 by Chris (aka Seedubs), on Flickr
Test 2
The third image was produced using Photomatix (3 image Exposure Fusion) then levels/crop/sharpening in Lightroom (LR) and then finally into Irfanfiew for the canvas size adjust (black surround):
3.
3 Pic fused1 by Chris (aka Seedubs), on Flickr
Test 3
The fourth image was produced using Photomatix (3 image Tone Mapping) then levels/crop/sharpening in Lightroom (LR) and then finally into Irfanfiew for the canvas size adjust (black surround):
4.
Tonemapped3 by Chris (aka Seedubs), on Flickr
Test 4
The fifth image was produced using only using the Lightroom Enfused plugin and directed exported to Irfanfiew for levels, sharpening and the canvas size adjust (black surround):
5.
EnfusedIrfanView by Chris (aka Seedubs), on Flickr
Test 5
The final sixth image was produced using the Lightroom Enfused plugin, then levels/crop/sharpening in Lightroom (LR) and then finally into Irfanfiew for the canvas size adjust (black surround):
6.
Enfuse1 by Chris (aka Seedubs), on Flickr
Test 6
Any advice or pointers good or bad would be appreicated, or suggestions on better use of Photomatix or LR.......MTIA
1.
Original (1)
2.
Test 2
3.
Test 3
4.
Test 4
5.
Test 5
6.
Test 6
