I’m doing photos and filming so it’s an interesting idea. I’m not convinced of the practicality in the canon promo video of switching back and forth between photo and video mode - I rarely film handheld so the filming camera is likely rigged up with sound and on a tripod or gimbal etc.I’ve yet to shoot any video on my R5 but that would be waaaaay beyond my needs!
Interesting that you have to switch it off to move from stills to movie.
No issues on my side. What sort of shooting conditions are you experiencing this with?Has anyone had any autofocus issues with R5/R6 since last firmware update?
When out recently, there is sometimes some drift in the focus points in the vf, whereas it used to lock on and stay locked on. I wondered if it was just my imagination but the net seems to have a number of similar stories and my experience also started after firmware v1.5 was installed.
Largely when there is less light but in good light with shadows sometimes too.No issues on my side. What sort of shooting conditions are you experiencing this with?
And nothing strange in the settings?Largely when there is less light but in good light with shadows sometimes too.
Focus used to be maintained in a rock solid fashion at selected focus point, however now it sometimes brings up just a random block of focissung squares off to the side of where focus originally was!
Nope, even went back to reset and set up again.Twice!And nothing strange in the settings?
Thanks for feeding back. I was interested to see how you would get on - nearly said so at the time, but have come back looking for your feedback as I am due to shoot under floodlights again (grass roots).So the R5 I had for 2 weeks went back today. The short story is.. Not for me..
Just a reminder... I needed the camera for sport using ISO 51200 f2.8 and usually a 640 or better shutter on a 400mm lens and even then getting under exposed ... So maxing it out really.. my requirements where a 2000 pixel jpg file and to shoot in jpg.
Under the above conditions the same as I would use on a 1dxII I expected the ISO capabilities to be simmilar But the added MP resized down to 25% would make for much better pictures.. It didnt.. i found iso 51200 under the above? more blockey and thus the resulting resize not as good as expected..
The eye focus was great even in those conditions. very impressive. but limited use for sport with multiple subjects in close proximity and me wanting to choose one player over another.. No problem revert to spot
however the deal breaker was (again in extreme conditions using a 400) it took too long to aquire a subject..it was hunting if the target was too far from the last target it focused on... the hunting was only a second but thats a lifetime in sports and would lose me the shots.. my 1dx and 1dxII aquired faster
Now I know r5 users are going to argue the points.. But have you really shot moving subjects in exactly the same obove conditions? No point telling me to shoot raw either... the point was to shoot the same as I am now wiht better results...
I can imagine all the advantages in other situations.. especialy the ability to crop in more under better conditions and I do use the camera on the floor a lot so the flip screen great and lots more advantages.... But thats not why I wanted one... it was for the above![]()
I’ve not got that one. Nothing changed for flash as far as I know.Quick question: has anyone used a Canon MT-24EX Macro Twin Lite flash with the R5/R6? (not the latest version, which is the MT26EX). If so, any issues.?
I’ve just ordered an R6 and I’m hoping that my twin light will work ok with the R6. I don’t see why not, but I’m not sure if anything changed wrt flash technology with the R series that would make it incompatible.
Thanks.
EDIT: it looks as though it is compatible. Anyone tried it?
Thanks Tim - that’s good to know.I’ve not got that one. Nothing changed for flash as far as I know.
Them's the ones, yes. They work well, the camera doesn't come with any warnings etc. Only bought 2 months ago though.do you have a link for the Neewer ones? I’ve found these on Amazon
I use these two when needed, very convenient.- bulb timer
- intervalometer
Haven't use yet but should be easier than MFHas anyone used the multiple focus settings? I meant to try it this weekend but forgot and ended up manually focusing/stacking!
LP-E6N, Neewer, I've used these in my 7DII for years with no issues.I wonder if you kind folks could help with recommendations for a 3rd party battery that will work in my EOS R and also my Canon charger.
I'm hovering over Duracell's equivalent of the LP-E6N but thought I would ask before I purchase.
Cheers!
You having issues?....rolling back firmware 1.5 to 1.4 here....this video helpedView: https://www.youtube.com/watch?v=L14iQ0aYoO0
Not so far, however there are a lot of reports of worse AF performance and freezes and I don't want to take the risk. V1.4 is good so I'll leave it there until Canon sort out the problems.You having issues?
Good to know it's better. I can't take the risk given all the reports of AF jumping around and freezing so I've just done the rollback for two cameras using this method. It worked fine for both.I’m on version 1.5 had no issues
at the moment am using eye tracking focus a lot and its even better than before picks up very fast
its not easy as far as I know to go back to a previous version, can be done but involves swapping memory cards during the process from what I’ve read , I would be very wary of doing this with an expensive camera
I guess it happens in some situationsGood to know it's better. I can't take the risk given all the reports of AF jumping around and freezing so I've just done the rollback for two cameras using this method. It worked fine for both.
Right, next up is a team sports assignment and it will for sure be busy with faces which prompted the roll-back.I guess it happens in some situations
I had a couple of times when the camera locked up before the update but it’s been fine since
I have heard about people having issues with this update though on the Fredmiranda American forum, I think it can cause problems with busy backgrounds as the eye AF is now more sensitive
