videonastie
- No
Can anyone point me in the direction of a "how to" for 5DMK3 focus adjustment?
Except Focal doesn't auto calibrate with the 5D3.
You can still use it to help manually calibrate it though - I've done it with my 5D3
I've used FoCal with my 5DMKIII. Although its not fully automatic (you have to set the micro adjustments manually), the software makes the process very easy to understand and do.
I like Focal and have the Pro version, but for my 5D3 I don't bother with it as I find the manual tweaks to be too tedious. Instead I use a method discovered by Arash Hazeghi, which uses EOS Utility and Live view to determine the most suitable AFMA value by nudging focus from the laptop/PC until the sharpest image is obtained. Just count the nudges required, and the direction, and input the count as your AFMA value....
http://arihazeghiphotography.com/MA-web/
Something else I've seen, but have yet to try, is the approach described here....
http://www.fredmiranda.com/forum/topic/1187247
I could be wrong, but I think the latest Focal release candidate includes a new calibration method which uses this very technique. I tried it out with my 7D yesterday and got results within 1 or 2 increments of my previous adjustments. It is undoubtedly quick and painless, but only automates something we could do for ourselves with some tedium.
It's such a shame that these automated approaches still can't be fully applied to the 5D3 due to Canon's annoying unwillingness to allow the SDK to change AFMA values through software.
