canon 580ex mk2 flash only firing at full power
stumac
stuart
As per title I was shooting a wedding yesterday and without warning my flash would only fire at full power in ettl.
when in manual(on flash) it works as normal.
anyone came across this before
similar has happened with one of my flashes the reason was it wasn't fully seated on the hot shoe ( not full pushed in to the hot shoe )
the thoughts of what was happening is the pins wern't quite mated up properly but with the centre pin being larger than the others that one was making proper contact and would fire the flash at full tilt as if it was a manual only flash
might be worth a check to see if you have the same problem
the other thing that comes to mind is a dirty contact stopping ETTL communicating with the flash properly
switch cleaner and a cotton bud would cure that
Thank you I'll try cleaning the contacts .
