Canon 24-105 Noise ( Not IS )
Throttle
Hi
I recently purchased off the forum classifieds a Canon 24-105 and i've noticed today on its first test run that when i use the Zoom ring it makes a grinding noise.
I don't know if its me but im bit concerned that its on the start of a potential fault occurring or is the noise common on the 24-105, I haven't heard it on any of my other lenses tbh :thinking:
I've attached a quick video i made ( I can make a much better video should it be more helpful )
http://youtu.be/umASwhZdH5U
When i refered too not IS i was on about the noise, thats its not the IS motor BTW !
It's not right fella. Sounds like it could be a bit of grit that will go away with use, but otherwise there's perhaps something loose that needs fixing.
I have the 24-105 purchased 2nd hand from MBP. It definitely does not make a noise like that.
Cheers for confirming what i thought, that its not normal :(
Too look at it appears well looked after but obviously something isn't right and i don't fancy a potential repair bill so soon after just buying.. time to get onto the seller i think.
Good luck with that then - seems like these 24-105's are more trouble than they're worth.
