In addition to what the guys already told you here, you can also re-use original metallic canisters to get the proper DX code, I've mentioned this in the other thread where you asked about using bulk film, no need to buy new blank canisters.
You have two options with used canisters:
- If the original film was pulled off completely, then you will have to open the canister very carefully to not damage it (you can find
canister openers on the net), then attach the new bulk film to the spool, like you do with a plastic blank canister.
- This is what I do to re-use an metallic canister, when pulling out the already exposed original film to develop, I cut it leaving a few centimeters behind, out of the canister like some king of a tongue, and then use that tongue to attach the bulk film with tape, that way I avoid to open the canister and so keep it light tight. Like this guy here:
https://www.youtube.com/watch?v=-eqnuilNnAM
View: https://www.youtube.com/watch?v=-eqnuilNnAM
If the auto-rewind of your camera pulls all the film in the canister, again you have two options to retrieve and pull it out if you do not wish to open the canister:
- Buy a
film retriever.
- Do it manually, there are a few methods out there, one involves the use of water but I do not like it, the one that works for me every time is as follow:
View: https://www.youtube.com/watch?v=Uc00ULY7cYU
Hope this helps
