BunnyPics
- Oksana
Correction. D7000 is not on cards anymore. It's between D300s and D7100, and leaning towards D300s.
Thank you everybody!
It's now turning into eeny, meeny, miny, moe situation and the more I think the more confused I now get. My ADHD is getting the better of me now, I'm going crazy and I need help.
I've outgrown my D5100. For about a year I've not used anything other than the full manual mode on it and shot in RAW only. I'm OK with the camera, but I've stumbled over more and more limitations and I need to upgrade. My dad's a pro and he despises all Nikon models with 4 numbers in them, I think, so he appears quite biased towards D300s. My argument in favour of D7000 over D300s was the supposedly better exposure metering, probably quicker focusing in low light.
The push for the upgrade came from my needing fast flash sync, in-camera focus to be able to use older lenses without ultrasound motors, in-camera autofocus adjustment.
Both are an upgrade from the dinky D5100 for me: pentaprism viewfinder, 100% viewfinder coverage, they are bigger and heavier and have the little monochrome screen at the top where you can see all the settings.
... and I like the virtual horizon on them!
Deciding factors would be:
- autofocus because I often shoot in mediocre lighting and also moving subjects - pet animals (which seems to give D7000 an advantage, but is there a noticeable difference in speed? Or does D300 have the advantage because of more focus points including the cross ones?)
- exposure metering (D300s' sensor has less pixels for this but again I will probably not notice the difference, or will I in low lighting?)
- the size of the little control panel display at the top. I read somewhere that it is tiny and unusable in D7000. Is this true? Is D300s' control panel bigger in size?
- The look and the feel of the camera! I want it to "look good"
- Video capability
- Megapixels
- Continuous burst of 6fps is sufficient, more would be an advantage but not a deciding factor
- Buffer size
- I don't shoot at very high ISO. 640 is probably the ceiling for me. It's normally a reflective flash and about 200-400 in low lighting.
- CF card slot is not critical. In fact, I don't have any of them at all
- In-camera editing
