Can I pick a mechanics brain please
Borats Baby
Rikki
1999 Ford Mondeo 1.8TD
As you look at the front of the bumper, at the bottom, inbetween where the fog lights would be, is a grille. ie, NOT the chrome oval grille up top.
behind the grille is a pipe which is about a foot and a half long which bends back on itself and goes across the top of it. The top half has fins on it, bit like the pic below.
Any idea what it is as its leaking from one of the joints ?
It has got air con, the fluid is grey and watery. Although it does have a slightly oily feel.
power steering cooler pipe, melevo is a ford man
ebay 370181110237
thats half a dealer price so not bad tbh, and if your fluid is grey then it never been changed and WELL past its sell by date, it goes grey when it loses all it properties
Give your local Ford Dealer a call ask for the parts department and quote this number: 1093421
The will tell you how much they are.
Be very aware though if it is leaking.
If the sytems runs dry 60 quid will be cheaper than replacing your steering rack and pump!
