??? ISO is not merely an exif header setting (to be applied by software)... the amplification is real and it does change the data recorded. I am unaware of any camera where this is not the case.Only a few cameras rely on amplifying the signal now
Not quite, but the firmware can... that's the difference between analog ISO settings (amplified signal), and extended/digital ISO settings (firmware). But often you may not know where that switch occurs (with Nikons it used to be the Hi and Low settings, but now they don't necessarily tell you).All sensors have a native ISO. they do not suddenly become more sensitive when you up the ISO. The firmware in the camera changes the way the captured data is handled when you change the ISO.setting.
Most of the current Nikons, the Canon 80D is supposedly close, Sony A7r series, several Fuji X models, K5... IDK of any up to date list.So which cameras are iso invariant?
No, analog gain is still applied for all "native" (analog) ISO levels. See the link in post #8 for the D850, one of the most ISO invariant cameras currently available...An invariant sensor does not change the gain at the analogue stage but merely amplifies (multiplies) the recorded signal level after it has been converted to a digital value.....as would the brightness slider in PP
Yes.So ISO invariance means, for example, that you can shoot at ISO 400, increase exposure by 3 stops in post and this would give the same result as shooting at ISO 3200 in terms of noise?
These measures are based on a "proper exposure" of the same test scene. And ISO 3200 results in less DR because the sensor receives less total light (less saturation at the high end, min is always the same). So the answer to your question depends on the scene and how the ISO invariance is used... if you use ISO 400 you will have recorded 13stops DR *if* at least some photosites reach saturation. But if you use ISO 400 and significantly underexpose everything, then you will have something less than 13stops of DR.On the D850 the DR at 400 is approx 13ev, yet at 3200 it's around 10.2ev.
Thanks, that makes senseYes.
This is the best article I could find... still a bit more convoluted than it needs to be.
I should clarify...Thanks, that makes sense![]()
The 80D has much better DR than it's big brother, the 6DmkII, but only up to 400 ISO. I don't really understand how all this works but I see this pushed a lot when I look at 6DII reviews.
Replying to yourself.welcome to the nuthouse,glad to have some companyI'll just google it![]()
Replying to yourself.welcome to the nuthouse,glad to have some company![]()
That’s true in a lot of things like food exercise or most personal stuff,nobody can know yourself like you .
But just incase,this might help
The more sophisticated design of the 80D's sensor means it adds less noise to its images than its big brother. This means that, at low ISO settings, the 80D will produce more flexible Raw files, that make it easier to represent the detail in high-contrast scenes, before you hit the noise floor. If you've become used to exploiting the 80D's pretty impressive dynamic range, it may be a bit of a shock to find you end up with more prominent noise if you try to manipulate an image shot in high-DR circumstances, such as sunsets or backlit subjects.
That said, we're aware that a great many people primarily shoot JPEG. Since the differences in performance between the two cameras' sensors tends to occur in very dark tones within the image, so may well be either too dark to perceive or clipped entirely to black if you're only looking at JPEG images. Even engaging Auto Lighting Optimizer or Highlight Tone Priority - the camera's two DR compression modes that risk pulling noise into the image - isn't a problem (though it's interesting you can't use the two in conjunction). However, you don't get the noise improvement at low ISO you might reasonably expect from the move to full-frame.
I think it's helpful to remember that actual 'exposure' to light (total photon capture) only involves shutter speed and lens aperture. ISO makes no difference to that - it just amplifies the signal and adjusts brightness to the right level.
Film has a fixed sensitivity, indicated by the ISO rating, and it cannot be changed. Digital also has a fixed sensitivity - the native or base ISO - but the effective sensitivity can be changed by adjusting the gain applied (amplification).
Traditionally, applying gain to the analogue signal at sensor level produces much better results than doing it in post-processing software after the analogue-to-digital conversion has taken place in-camera (as Steven explains). With a truly 'ISO-invariant' or 'ISO-less' sensor, it would make no difference whether the gain was applied in-camera with ISO adjustment, or afterwards with post-processing software - the quality of the result (basically in terms of shadow detail and noise) would be the same. No camera is currently 100% ISO-invariant, though some do seem to get pretty close.
There are several practical applications of this, and they can be very beneficial, but it does not mean that shutter speed and aperture settings no longer matter. They do, and ultimately the quality of the result is always directly related to total photon capture.
...... but given that best exposure always depends on maximum possible photon capture regardless.........,
What you probably don't see being pushed is that the original 6D is reputedly around 'half a stop' lower in noise than the 6D Mk 2 at higher ISOs, which is another reason I've still got my 6D.The 80D has much better DR than it's big brother, the 6DmkII, but only up to 400 ISO. I don't really understand how all this works but I see this pushed a lot when I look at 6DII reviews.
About time someone said that in this thread!!
Perfect ISO Invariance doesn't exists, and neither does smooth linear analog sensor gain, but careful use of either/both can help, but getting the exposure right in the first place will bring the most benefits.
One of the many benefits of mirrorless technology with WYSIWYG EVF'sAbout time someone said that in this thread!!
A bit more on the practical applications of ISO-invariance.
In these debates, it's quite common for some to argue that with an ISO-invariant sensor, exposure settings don't matter - just shoot at base ISO with whatever shutter speed and aperture you want for creative purposes and adjust brightness in post-processing - based on the fact that photon capture will be the same whether whether ISO is adjusted or not. That may be true in very rare instances where base ISO also happens to be right for normal exposure setting purposes, and there's certainly more leeway, but given that best exposure always depends on maximum possible photon capture regardless, the only way of optimising that is to adjust exposure settings in the normal way so you know where you are. With that done, an ISO-invariant sensor may allow you to make further beneficial adjustments.
ISO-invariance changes the popular method of optimising digital exposure known at ETTR - Expose To The Right (of the histogram). This basically means over-exposing to put more detail (photons) into the shadows, then darkening the image back down again in post-processing but with shadow detail retained. It works well but there is a downside because over-exposure will blow highlights so a careful judgement must be made to make sure only unimportant highlights are effected - basically, it's a compromise.
With ISO-invariance, that technique can be changed to ETTL (Expose To The Left) which ensures that all highlights are retained and shadows can be lifted in post with little or no penalty. In some situations with very high dynamic range where you might otherwise need multi-exposure HDR technique, it can make a big difference, eg most back-lit situations where you want detail in the very bright background but also good detail on the shaded foreground. Unlike HDR, ISO-invariance also works with moving subjects as everything is captured in a single shot and since it often means you can use a faster shutter speed, that's another bonus.
A practical downside of ETTL and deliberate under-exposure is that the LCD image goes dark, sometimes very dark to the point of useless, and the histogram will also reflect that.
Exploiting the full potential of ISO-invariance only works when shooting Raw. It's not much use with JPEGs where tonal values are pretty much locked with very little scope for adjustment in post.
how do you define " getting exposure right"
I would tend to define it as capturing "all the needed and significant tones in an image".
This is quite different to what a camera or exposure meter normally does unaided.
nor does it necessarily produce a pleasing result directly out of the camera.
I only ever shoot RAW and pretty much ettl slightly, it works even though I'm constantly told to ettr, when I shoot using constant view, one of the many benefits of mirrorless, I see what I will get and I don't push it far enough to need to pump it tonnes in post. With a DSLR ovf I'd have to chimp a bit more I guess?
But mirrorless is not inherently WYSIWYG when you start to play about with ETTR and ETTL. What you're seeing through the EVF or rear LCD is a JPEG generated in-camera, so it can't show what you'll get after adjusting the Raw file in post-processing. Cameras vary in how they adjust image brightness for viewing with exposure simulation etc and the histogram will certainly be unhelpful.
It's an interesting dilemma. No current camera is designed to be operated using these techniques, ISO-invariant or not, but given that it's likely to become more popular and even commonplace in the future, camera manufacturers might want to address it, at least with enthusiast-oriented models.
.'Correct' exposure, in theory, is when mid-tones in the subject exactly match mid-tones recorded by the sensor and are output as mid-tones without adjustment in post-processing. This is what the meter tries to do and will deliver good looking JPEGs straight out of the camera. But 'best' or 'optimum' exposure may be very different and can be anything you want it to be with a good understanding of how it all works. And all cameras vary with what's possible and how far you can push things. ISO-invariant cameras are new and only a handful really fit the bill (mainly Sony and Nikon).
The only way around is to quick adjust to as near as possible to your on cam settings upon import to LR maybe?
