- No
Hi Ruth.
Try bouncing your pop up flash indoors to make the kit lens work inside! Set it to the highest power and in manual mode, have your hand direct the flash up to a ceiling. The light will then 'bounce' from the ceiling onto your subject and allow you to use lower ISO and faster shutter speeds. See- you don't even need to buy a flash unit when you know how![]()
Excellent advice for using pop up flash.
Even better if you use a piece of white card or paper to bounce it up.
