Yep, awning attaches to the side of the truck then has two poles to support it, in hand!
It will also shelter me from the blazing sun and high temperatures of the highlands of scotland in November!
Dinae forget a flashing beacon, to warn the snowplough crew that you are stuck in a drift.
Seriously though, the days are short in November so be prepared for long dark nights in your vehicle.
Mark, I use general grabber AT2s, had them on the hilux and now on the patrol. Great off road tyre that are not overly noisy on the road,very hard wearing as well.
Seriously mate, I`ve told loads of keepers,water baliffs and stalkers about them, many have them on 4x4s now.Very good tyre.Sound like a good choice. I'll see what my tyre man can do me a deal on.
Great project - hope trip goes well.
Having slept in vehicles just one piece of advise, don't skimp on the insulation.
A tent and decent sleeping bag is warmer than an ordinary vehicle so insulation is the key
November in scotland is likely to be horizantal rain
Sounds like its taking shape! Looking forward to seeing the end results.
Mark, the LED lightbar may not be ideal. It's being noted that LED traffic lights, bright though they are, don't generate enough heat to melt the snow that falls or is blown on to them.Flashing beacon (well, low level LED lightbar, the modern equivalent) organised![]()
I wouldn't bother to mention it, except that I'm personally all too familiar with the phrase "b****r, who knew!?"![]()
You mentioned the spots on the front being wired in to the main beam. Are you using the main beam as a trigger wire for relays? If you're just planning on taking a feed off them - don't - put a new fused feed direct from the positive terminal on the battery to the relays, trigger on the main beam wire - you'll get the full 13.8V to the lights and safeguard your main beams at the same time!
Definitely get busy with the insulation. Also have a look on ebay for 'eberspacer heater' blown hot air heater - run it off your main fuel tank - fire it up when you need it. They're neat little things and will make you happy and warm.
John got no cheapo cayennes then ? The road down loch ness on the non touristy side is quite interesting (east side).. loads of wildlife etc..have a good trip , Steve w.
Where's the photos!
big soft moose said:I wanna see a build thread with lots of piccies
markmullen said:I'll get some photos tomorrow.
