Bluetooth help needed ...
Paulie-W
Paul
Amp is a received not a source, or do you literally just want wireless speakers?
Haha I got my ipod and tuner running into the amp, so ideally, would like to send from the amp to wireless speakers.
Or something like this. Get it together with the line out to 3.5mm adapter and just choose any Bluetooth stereo speaker you like.
I like your thinking as the advantage of putting it on a switched amp is naturally that one device can serve many sources.
That`s what I thought, but it seems to be proving more tricky to find stuff. The speakers ideally would be left outside, mounted to a pergola :)
Ok what I`m trying to do, is send to some outdoor speakers, via my old hifi. After numerous searches and head scratching, I`ve found these.
http://www.amazon.co.uk/dp/B00IFZMN...=UTF8&colid=LDA0MSKP8I0L&coliid=IXOEEOY48374R
http://www.amazon.co.uk/dp/B00LAZ6R...colid=LDA0MSKP8I0L&coliid=IBXBT1VIJZ11X&psc=1
As the speakers are only going to be for casual use, sound quality isn`t a massive priority. I just want something that works :)
Any advice would be greatly appreciated.
Tia
The second link look pretty good. Does your amp have a line out? If so, it look like you could wire the line out from the amp to the Bluetooth sender, then either have another one acting as receiver wired to an active speaker, or buy a Bluetooth speaker. Unsure what the range like on info these though.
Pre amp or tape out rec or headphone socket.
