- Mike
I tend to shoot quite a bit of Black & White photography & always try to visualise the shot in mono before I take it (not always successful obviously
) I then convert to B&W via post processing for the most control.
Others that I know & have spoken to tend to take the shot first & then see if B&W would work to enhance the shot at all (I also do this sometimes), whilst others shoot B&W straight from camera, keeping a RAW file with the colour information if required.
When shooting for B&W, aside from the usual compositional considerations, I tend to look for high contrast areas within the scene & also hard edges, curves & clearly defined details for added interest, trying to avoid similar tones being too close together (although if working digitally, this may be remedied to some extent within the channel mixer, etc.)
Upon a recent thread I was discussing Mono techniques with Creed & thought I'd see how others worked with this, if anyone had any tips on their B&W workflow they would be willing to share & also any ideas as to whether/how you go about visualising the shot as a B&W or whether you rely upon the post processing more?
Edit: 1st tip should come from me I suppose
When using the Channel mixer, the first thing that I do is drop the RED channel down from 100% to 0% and begin instead with the GREEN channel set to 100% as I find that nine times out of ten the green channel gives the best beginning point for midtones (can be easily checked via the channels menu)
) I then convert to B&W via post processing for the most control.Others that I know & have spoken to tend to take the shot first & then see if B&W would work to enhance the shot at all (I also do this sometimes), whilst others shoot B&W straight from camera, keeping a RAW file with the colour information if required.
