menthel
- Jim
Ok, what I want to do is work out the best way to set up my iMac for LR4, whilst also being able to backup. I have a May 2011 27" iMac i5 wtih 12gb RAM, a 1TB hdd. Attached to it is a 1TB 2.5" HDD which is backed up to. I have connected wirelessly, a time machine which is used for mac backups and also contains my RAW files that I work from and the finished Jpegs etc.
I find the whole process a little slow and I have to 'find' the RAW files on the TM every time I open up LR, which is a little annoying. My catalogue is stored locally on my internal HDD.
So what I want is a way to speed my workflow, stop the disconnections and back up safely and effectively.
2 caveats- no ethernet wiring (not possible) and no fiddling around inside the iMac (I don't want to replace the hard drive in there- looks too complicated!).
So, what do you recommend? New storage? Best place to keep RAW files, catalogues etc?
