snerkler
- Toby
- No
Just because it's designed for bokeh doesn't necessarily mean it's the bestIf you want to keep open the option of purchasing a lens specifically for the purpose of the best possible bokeh quality, that lens is the Sony/Minolta 135mm STF f2.8 [T4.5], designed quite specifically for that sole purpose, using an apodisation filter instead of a conventional iris. It does have two conventional irises as well, one of which operated manually, the other of which is operated under camera control. To be able to use that lens you will require ideally a Sony A-mount camera, which can mount it directly, or a camera which can mount it with a glassless adapter, such as a mirrorless camera or any DSLR with enough of a shorter registration distance than the Sony A-mount to accommodate an adapter.
I just wanted to alert you to the difficulties and complexities, not to mention the costs, which beset the path of the Ultimate Bokeh Seeker![]()
DSC_2501
