it has been pointed out the file type doesnt not affect the exposure settings.
Actually I would say it does. If you shoot to raw then ETTR (Expose to the right) is a valuable technique for capturing maximum tonal detail and minimising noise. You will also have more headroom to recover "blown" highlights if need be when you shoot to raw. If you shoot to JPEG then really you need to shoot to get the correct exposure in camera, and you will not have the luxury of highlight recovery. Where I might meter at +3 off the dress when shooting to raw I would probably only meter at +2 if shooting JPEG. Mind you, as I never shoot JPEG I'm not sure quite what the limits are. I'm guessing I'd want about 1 stop of extra safety margin.
Well this has to be one of the strangest wedding threads I've seen. I have to go with Toothie's post and ask which are you?
Having a sense of humour here goes a long way, trust me!(and some not quite as useful....)
Hi
I've just had a gander at your site. Very Nice!
I like your style You do seem to capture the essence of a person in the images. Beautiful.......Do you swap between Manual and AV?
I think i've been making things a little complicated, when really they don't need to be.....
Thanks for your straight forward tip...
sorry to go off topic does exposing to the right mean you over expose as thats the right hand side of the histogram, or under expose and shift it to the right later?
Thanks for your comments, Thanks to Tdodd your explanation of what each setting actually does made things so much Clearer . And also to Radiohead Your tip for staying on AV and altering the shutter by changing the ISO is a good one to remember. I just need to get on with it and practice around these functions to get used to using them. I am up to speed with Manual and being able to judge what the correct combination of ISO, Shutter and Aperture should be depending on the subject and lighting conditions, but was concerned that this would be to slow when having to react quickly in a wedding or event situation. My first Two weddings were done in a mixture of Automatic and Manual on JPEG. And i have never used TV, P or AV in this situation. Thats why i posted the question.
In answer to the question posted earlier. 'am i a Pro stirring things up or a Amateur'. Well, i am an amateur trying to learn as much as i can, in the hope at some point i might be a decent photographer.We all have to start somewhere right.
M - ... no real point in using this mode for anything else since you are using the camera's meter.
Your camera's meter evaluates the scene correctly in all circumstances? Wow!
i very seldom have time for manual at weddings.
(sits back and waits for comment)
Don't get me wrong, I am not against Manual and use it wherever I can and for all the reasons you also mention...but, personally, I rarely use it on weddings.
What I am against is people who very openly proclaim that full Manual is the only way to shoot to be a "real photographer". Especially when those peeps have never done a wedding before.
OK, rant mode off...
When shooting on Raw at a wedding is it best to shoot on P Mode or AV or TV.
Josephine:bonk:
How about none. And how about I suggest that you don't even attempt to do a wedding until you understand how to use a camera.
You should be shooting manual [m]
I can think of 2 or 3 dozen reasons for using manual at a wedding, and only one for using the likes of AV - and thats that you don't know what you are doing.
and there is no reason a professional would ever use P
I wonder if you have actually read the rest of this thread, the OP has already stated that she has shot weddings before.
... The meter is a very simple piece of equipment it's not intelligent in anyway ...
With a post rate of one per month, I don't think there's much chance of repetition!see how many you can actually list without repeating yourself
Surely what's important is what's captured, not how it's captured :shrug:
DD
That would be like poster #67 then
I happen to know one of Britain's best Wedding togs uses P most of the time too
DD
I think that would make fine reading.Do us a favour mate - and see how many you can actually list without repeating yourself
DD
