I've got a rental property which is heated by oil with the boiler in the garage. Unfortunately my usual plumber is unwell at the moment and I've got a quote for the following works from one used by my letting agent with a breakdown of the work.
If anyone in the trade could please advise if this seems reasonable I would appreciate it. The reason for asking is that the first quote was a single figure and when I asked for an anlaysis the total dropped by £300 ! I just want to check that this guy isn't still trying to lift my leg for the work
Replace 6 thermostatic radiator valves
- Add a suitable inhibitor
- Recommission radiators and balance £ 255.00 + vat
- Replace the old circulation pump and valves including labour £ 150.00 + vat
Highly recommended as the existing pump is elderly
This cost is only if applicable if done at the same time as the job above
- Install a wireless programmable room thermostat - including labour
Installing this will give better timed control and allow the choice of room the
temperature is measured in.
- Install an up to date method of frost protection for the boiler in the garage to
include a new frost stat and a pipe stat - including labour £ 160.00 + vat
- Service of the boiler, visual oil tank inspection, service/maintenance certificate including a nozzle, filter and 2 x motor bearings £ 132.00 + vat
The cost of the above work materials and labour is £ 697.00
Plus VAT £ 139.00
Total £ 836.00
Any advice appreciated
Plus VAT £ 139.00
Total £ 836.00
