advice re an old PC
Building a PC from components is easy enough. There are only a handful of basic components & they simply slot together. Care needs to be taken to avoid static discharge when handing components such as CPUs & memory. As to whether you could reuse parts of the old PC, it would depend upon who built it. Some brands (e.g. DELL) in the past have used proprietary motherboards, power supplies, connectors & cases making them more difficult to swap major components.
Someone experienced could probably assemble a PC from scratch in 30-40 mins, loading the software would take a lot longer, several hours depending upon what you wanted installing.
Assembling a PC from components may not save you much money vs buying a new one but might lead to greater self-satisfaction. There are plenty of companies that will build PCs for you, or you might be lucky & pick up a bargain 'factory refurbished PC' from a mainstream supplier like DELL, Lenovo etc. I recently purchased a £480 DELL refurb system unit based upon a 3.6ghz Intel i7 with a 500gb HDD, 8gb memory and Win 8.1 for less than it would have cost me to purchase the component parts. At the same time I built a 'headless' mini-ITX based USFF system to act as a data-logger for a weather station for £200 reusing memory & SSD I already had.
My advice would be decide what you want it for & arrive at a specification, make a shopping list of components & then price up a DIY PC vs one off the shelf.
Probably the only thing you could recycle is the case.
As Brian says, you need to work out a spec first then figure out the costs.
There are tons of threads about what makes a good computer on here.
If you get stuck, we live in the same town:)
I still got my old computer its in an huge Thermaltake case,still like having a mess around inside and upgrading :)
You need to look at what components are in the PC you have, you may well be able to use the case, power supply and hard drive (at least as a second drive, or use it for the time being and add a second bigger/faster one later). Check the power rating on the power supply and whether it has compatible connectors for the mother board you intend to buy.
If this were a computer forum rather than a photography forum, someone would, by now, have suggested just putting Linux on the PC, adding a couple of big hard drives and using it as a file server...
The big question is whether the power supply has sata style power connectors (wider, slim and L shaped) or 4 pin molex connectors for disks (chunkier)
Naah, way to power hungry!
Or buy a Molex-SATA adaptor for £2
Add an RTL SDR stick, DIY antenna, Dump1090 and run it as a ADS-B/mode-s feed to Planeplotter.. ..
(just to be different - otherwise new hard drive and Ubuntu if you'd just prefer a general web browsing/home-office box)
