Advice on Lens choice... yes a D40 owner...
Iiyama
Hi folks. I have read, searched and read again. Each time I read something another lens pops into the equation!
I take a variety of photographs from landscapes to candid and seated portraits. After going from a FZ5 super zoom I miss the ability to get closer to the subject without them always noticing. I'm also going on holiday to Thailand so prefer the single lens solution.
I have narrowed it down to:
Tamron 18-250mm F3.5-6.3 AF Di II LD Aspherical (IF) Macro (Nikon Motorised Fit for £295
Tamron 18-200mm f/3.8-5.6 XR DI II LD Aspherical (IF) AF Nikon at £289
Sigma 70-300mm f4-5.6 DG MACRO Lens (Nikon Motorised Fit) £100
Nikon 55-200mm F4-5.6G VR AF-S DX IF-ED at £125
I prefer to save money and spend under £200. But if the difference in the lens is significant I would take the plunge.
Help appreciated. Sample shots with these lenses at different lengths also appreciated.
The Tamron 18-200 is exceptionally good, I've used one as a backup on occasion on a D50, which has the same sensor as the D40.
Sample shot from the 18-200? Sure...
And a landscape (on my S5 Pro, also 6 megapixels)
The 55-200 VR is also really really good as well.
While the Tamron 18-200 is excellent, nowadays for a D40 I would recommend the Nikkor 18-55 VR kit lens, and the 55-200 VR. Superb combo, cheap, light, and under £200.
Here are some shots using the Nikon 55-200 VR at different focal lengths.Taken mainly under very gloomy weather conditions, by way of contrast to the above puddleduck photos.
At 50mm focal length. Part of photo.
At 145mm focal length
At 200mm focal length. The only sunny interval....
Thank you for the replies so far. There appears to be "noise" on Edward Bancrofts samples. I presume that's not the lens at that focal length causing that?
You presume correctly ;)
In general if you're faced with the choice between a Nikon lens and a third party one at the same sort of money then go Nikon every time.
The 55-200 VR was specifically designed for the D40/x and D60- at around £125, it's really a no-brainer ;)
That should be 55mm on the first picture.....
The third picture was set at 400ASA, so some quantisation noise on the image, exaggerated a little after Photoshop processing.
Edward.
