Adobe DNG converter
Rocket
CTID
Tony
Just downloaded the adobe DNG conveter to convert my raw files from my D300 so as to open in Photoshop CS2.
Opening the converter i select a folder where my raw is, click on the raw file, but as soon as i do that the select button becomes non active.
Any ideas please..
You need to select the folder not the file. You can't select an individual file only the folder that contains the RAW files. Also don't forget to select the correct compatibility for CS2. You'll find this option under "Change Preferences" not sure which option you need but I think it may be 4.1. If you get an error message from Photoshop select another option
Thanks John.
Yes that works fine I see now.
regards.
