Adobe Bridge Cannot open Camera RAW Error
Paul-H
Hi all
I am having a problem that I hope someone will be able to help me with
If I use Adobe Bridge and select anything to do with Camera RAW, either Open a file in RAW or even adjust Camera RAW preferences I get the following error message pop up
I don't know how long its been doing this as I don't usually use Bridge, I am using CS6 and have tried re-installing the software and using the latest Adobe Camera RAW but cannot get RAW to work in Bridge.
I did google the problem and it was suggested that the fix for this was to copy a file from the Photoshop Directory over to the Bridge Directory but that made no difference.
Anyone know why this is happening and what fix is.
Thanks for any help with this
Paul
When I click on a RAW file in Bridge it opens Photoshop and then Adobe Camera Raw. I assume you can open RAW files directly in ACR in CS6. If so I would advise you to make sure both CS6 and Bridge are completely un-installed and then reinstall CS6. If that does not do the job then I seem to recall there is a utility (I think on the Adobe site) which completely wipes all Photoshop/Bridge files allowing you to make a clean install.
Hopefully that will do the job for you.
Is it a fully legal copy of CS6?
I've seen this in the past with pirated copies of CS6 that required the copying of a few dlls from one directory to another but never seen it on legal copies.
