A Bit of Help With Batch Processing in CS5
GrittyShaker
Scott
Hello All :wave:,
I'm sure I've managed this before, but how I did it I don't know. :thinking: I'm just hoping someone can refresh my memory. I shall explain...
I've recorded an action in PS for a fake tilt shift effect. I want to process a large batch of files with the exact same look, as it's eventually going to be put together as a tilt shift effect time lapse.
I go to File>Automate>Batch, and select the source and destination folders etc. Here's where I get stuck.
When it does the first process in the action it wants me to click OK before it moves on, then the same with the second process, so on and so forth. How do I persuade it to do everything without any input from me? It's several hundred shots that will need doing, and I'm sick of clicking on OK. As I mantioned, I'm sure I've managed it before. I must be missing something this time around.
Any help gratefully received. Thanks. :)
do you not have to check the override all options box or something similar.....???
That's what I thought, but I've tried every permutation of ticky box, and it's having none of it. There must be something I'm doing wrong somewhere, but I feel like I've tried everything. :shrug:
