7D Exposure Compensation help
profiler
Derek
Hi Guys,
Hep required with the above.
I can change the 'exposure compensation' via the "QUICK SCREEN" but when I try with the rear main dial (after holding the shutter button half way) nothing happens.
Are there any camera settings I need to alter?
Any help much appreciated.
Hi its a while since i used the 7D but i think you set it via the custom menu settings ,ie set wheel for EV ,no doubt someone with a 7d will come along soon to help.
The setting is on custom settings as Den said. C.Fn1v.1.
Hope this helps
Silly question....you haven't got the switch on the lock position have you?
Bob
Hi Trev4,
When I select :- Camera function 1V.(operation others)
Then 1. jog down to 'rear dial' then set:-
=AV. press set, the choices are. Av Tv Af point direct
I can't see a choice for Exposure Compensation
Sorry for being a numpty
Hi Guys,
Well what a real numpty I am.:rolleyes:
Bob, It's not a silly question. SPOT ON:ty:
Many thanks for all your help, very much appreciated.
