50mm for Landscapes?
Marc
TPer Emeritus
When I bought my first Sony DSLR (A100) I bought a circular polarizer for the kit lens. I no longer use the kit lens, but I still have the filter which just happens to be the same size diameter as my 50mm f1.4 lens.
My question is, How good is a 50mm lens for landscapes? I'm a bit of a cheapskate (Or skint, whichever way you want to put it! :D) so I don't want to have to buy any more filters and the 50mm is the only lens I have of that size.
Anyone got any examples of pics taken with a 50mm lens using a circular polarizer?
Cheers.
Ok, not the best examples by a long way, but gives a quick idea. Largely untouched as I've not had time to do anything with them since last night.
HTH. :thumbs:
EDIT: Well, there's some pretty horrible things going on with the sky here, but I'm assuming that's down to dodgey resizing. The blue in #2 looks pretty sexy in the full size image.
Wide aperture lens isn't ideal for landscape, unless you're doing low light/night shots. Also, the trick with thread mounted filters is to buy the one that will fit your largest lens, then buy step-down rings for the smaller lenses.
I use mine for landscapes plenty and gives great results. Give it a try I say.
But I'll not be using it at wide apertures. Also, the point was that I already have the filter and don't want to buy another.
Galen Rowell reckoned that 90% of his published work could have been done with a 20mm and an 85mm, and the fifty is close enough to 85mm-equivalent on the crop format. Haven't found much use for one in landscapes myself though, perhaps I should try harder. :)
TBH, I prefer the 50mm than the wide-angle for landscape work.
Crude example below or 3 images stitched together (50mm, full frame on D3, portrait orientation).
The only thing about fast 50mm isn't the maximum aperture, it's the fact that the minimum is often less than f/22. I haven't got my 50 f/1.4 to hand but I'm pretty sure that it's minimum aperture is only f/16.
On the other hand, they recommend that for maximum sharpness with digital you don't stop right down so it might not be a disadvantage.
Fair point, didn't think of that, although I can't see myself stopping down that far anyway. Just had a quick check on my Sony f/1.4 and it does indeed go to f/22 :)
That's unusual, it's usually f/16 hence my previous comment.
It would be interesting to see what the image quality is like at f/22 on that lens.
Oh no, I'm not going to start another one of THOSE threads! :bonk::lol:
Seriously, I sincerely doubt I'd use it at f/22. I'm off out shortly to take some pics along the canal. I may give it a go, just to see, but I'm not promising to post the results! :nono::D
