AdeNeil, you really should not make sweeping statements like that, especially when you are wrong pal. Yeah, some lenses do not like tcs, the 300 and 500 f4s are fine with the 1.4. Never had a 400 2.8 Joe, but they are a big numb b****r when i have had the opportunity to use one.
Ade
I am not wrong I am speaking from experiance, I tried all the TC's on my new 300mm f2.8 and they degrade the picture IQ by ~30% and like I also said they also mess with AF by 50% ........................I cant speak for a 4 or 500 as I dont have them but on a 300mm they are crap pal
Honestly Neil, some of the best shots that I have taken, (I said I have taken, before I get the usual comments), have been with the 300mm f2.8 VR + TC20lll and before that with the 300mm f4 + TC14ll
Maybe the TC's that you have had have not been great copies ………… the best way for me to get to 900mm is DX D7100 + 300mm f2.8 + TC20lll = 1.5 x 300 x 2 = 900mm @ f5.6
I have not noticed any "softness" and at f5.6 not really any slower AF speeds.
Of course the 300mm F2.8VR is a stellar lens on its own ……… but the cost to get to 900mm at f5.6 is now affordable
Neil, the problems you are having are mainly down to lack of experience and user error. Sorry to be so harsh, but blaming your, very good, kit is just wrong. Look at some of the other exceptionally good bird photographers on here, look at the "lesser" kit they are getting results with, in far worse light than you get, and then try and tell me i`m wrong.Ade
Out of interest Bill you find stopping down a stop with the 300mm and 2x TC down to f/8 produces better quality images or is it fine at f/5.6? with my 70-200mm f/2.8 and 2x I always stop down to f/8 as it improves the images alot IMHO as its pretty softish wide open at f/5.6
Wrong I am stating facts.........you want to use TC's "go ahead" knock yourself out. For me I don't like them..............nuff saidNeil, the problems you are having are mainly down to lack of experience and user error. Sorry to be so harsh, but blaming your, very good, kit is just wrong. Look at some of the other exceptionally good bird photographers on here, look at the "lesser" kit they are getting results with, in far worse light than you get, and then try and tell me i`m wrong.
I`m not having a pop at you, please believe that bud, you can afford great kit and best of luck to you, enjoy what you do and keep at it. But the statement you are giving is just downright wrong fella.
FoCal is I think the best, (albeit probably the most expensive!).....but it takes any subjective element out of the equation.
Thanks george
£20 to £70 for the best pro version - just reading the review - need to check how to deal with longer lenses and if they do a mac version ……. plus that I can use it for 2 bodies - it looks like it works for up to 5 bodies
Hi Joe
If the light is good I find stopping down 2 stops can improve things but with the general light conditions so far this year I am always bumping up against high ISO's values to ensure that I get a high enough shutter speed - most of the time I try for near 1/1000 secs or over, even on a tripod, and I am prepared to sacrifice noise for central sharpness, i.e. sharpness on the bird, (that may seem like a contradiction, so maybe I have not explained it well).
So what I am saying is; so far I have let the deciding factor be shutter speed, then fvalue, and set a maximum of ISO 1600 using the auto ISO setting, (which is a complete reverse of what I did last year with the 300mm f4 …… 95% of the time I shot in Av mode at f4 and a max of ISO800 and let the shutter speed suffer).
But I am no expert in any way ……… just trying to figure it all out and can change my mind in a day.
Funnily enough, if I want a "good" image with the V1 + FT-1 and 70 200mm f2.8VR …….. I find that by far the best f value is f8 …… because the V1 only has single point focus with the FT-1 it always focuses with no problems at f8 in good light, below that I seem to have IQ problems.
Generally Joe, I find the 300mm f2.8VR very very good, I was over the moon when I got it after the first days shooting, I bought it used - the same when I used it with the TC20lll, again over the moon with the results and of course, the reach……… I paid less than half the new price of the VRll for the 300mm f2.8 VR ……. in great condition …..as new ………..I think that the glass quality is the same in both versions …… I will always try to buy used for these long Nikon primes as IMHO it is the only sensible affordable way.
I have not used the TC20lll yet with my 70 200mm f2.8VR, but I intend to give it a try
I suppose I'm learning all the time; and that the "right' light is a blessing as I find in S Africa ……… maybe that's why Glenn Bartley uses a flash on an extended bracket quite a lot particularly in not only indense forest type areas, (OK I know it is dark and and can have strong shadows), but in other places.
Take care
Bill
Nuff saidI haven't experience of Nikon,
George.
Yes Joe I did......."I sold them"I had to fine tune my TC-20EIII and 70-200mm the other week on my D800 as the sharpness was way out, After I fine tuned it started to produce some decent images, Have you tried fine tuning your converts? @ndwgolf
Optically the 300mm f/2.8 VR and the 300mm f/2.8 VR II are identical. The only differences between the two lenses are slightly improved VR capability and some fancy coatings. If there's any kind of price difference between the two, then the older version is likely to be better value.Interesting to hear how much you paid for the 300mm f/2.8VR I as I have read online the only difference between the two is the VR improvement, I will have to look into it more but if there is no major leap in quality different it is a lens I will seriously consider looking at.
RichardTwo reasons I bought the 600mm most people I know who have the 500mm have the 1.4 extender on a lot of the time
So you have a 5.6 lens the auto focus time is now a lot slower
And you have to bump up the iso to get your shutter speed back. That said the 500 is a great lens
Regards
Richard
I'm finding the Nikon 70-200 vr2 & TC-2.0III tele to be soft - even at f8. To the point I won't now use it on this lens - the TC-1.4II however works fine at f4...
Nuff said
Joe,
using TC's (any of them) will downgrade the IQ of the immage by at least 30%.......it will also effect the AF by about 50%..............................Head to the gym and work on your sholders and arms and you will be fine with a600mm f4![]()
The Nikon 300mm vr2 is awesome with the TC-1.4II - wide open (f4) & is soft with the TC-2.0III at f5.6.
f7.1 is ok & at f8 its back to life & perfectly usable.
Its OK to not agree; like wise I dont agree with you..................Neil, you took what i SAID OUT OF CONTEXT, please read ALL of my post, I really think you must be a trainee politician or Daily Mail correspondent Here is the full text.
Neil, I think you'll gather from the general opinion here that most people think you are just plain wrong, if you are getting poor results then I suspect you should check your equipment (or get it checked for you), or your technique.
No one, especially me, is getting at you but I would hate to see a newcomer read your posts and be put off buying teleconverters.
I haven't experience of Nikon, but I can't see them being substantially worse than Canon, I've made my points in posts above, and I'd reiterate that with a mk2 super-tele and mk3 extenders, the results are very impressive.
So, if anyone is reading this and swithering, I'd say go ahead, try it, rent if you want before buying, you won't be disappointed....is what I said.
Anyway, others and I have made the point that we don't agree with you, and I for one am now out of this discussion.
I cant speak for Canon as I dont own Cannon lenses just NikonIs this a reference to Nikon lenses or all makes when used with a TC?
....and if you're passing here, I'd love to let you have a look at the results I'm getting, I'm really surprised that it seems the Nikon ones are giving you poor results, there's another thread
http://www.talkphotography.co.uk/threads/canon-2x-extender-mkiii.542888/#post-6277809
ongoing about extenders, (again Canon) which seems to indicate another happy user?
George.
I just had a chat with a pal of mine who is an excellent photographer and who uses all the latest Nikon gear, and he says the Nikon extenders are not as good as the Canon ones, especially on the zoom lenses, so perhaps that explains some of Neil's problems.
He is also using their relatively new 80-400 lens (with D800, D4 and D4s bodies) and says it is really sharp, an excellent lens.
I wish Canon would bring out that focal length, but it looks like the new one will still be a 100-400, ie a direct replacement in terms of focal length.
_SGK5089-Edit.jpg by skersting66, on Flickr
Blue Gray Gnat Catcher by skersting66, on Flickr
