shiato storm
- No
just after a quick answer here, with Noise Reduction set to 'on' should it take a second frame - after the shutter has closed - equal to the length of the exposure time (above 1s i think it is which is similar to the 1DII I also use), and then perform a dark-frame subtraction prior to writing to the card... or does it employ an alternative method meaning quicker writing to the card?
I thought it used the first method (equal length 'exposure' with shutter closed) but recently with NR set to ON, it's writing to the card almost as soon as its shot until near or at 30s, after which it seems to be taking the dark frame as originally expected...
Is the 1dsII's operation different in that respect?
