- Les
Following on from these threads
http://www.talkphotography.co.uk/forums/showthread.php?t=116774
http://www.talkphotography.co.uk/forums/showthread.php?t=116689
http://www.talkphotography.co.uk/forums/showthread.php?t=116639
In which various options were discussed regarding the use of a 10stop ND filter, and some of the problems caused by a 'slot-in' type.
Lee (68lbs) very kindly sent me his slot in 10 stop ND filter (formatt) to try out, he had reported problems using it, notably 'blobs' of light appearing on his images.
I used the slot-in on a 24mm f1.4 lens, lee holder, Canon 1DS MKII, with the filter in the slot nearest the lens.
I also tried a comparison with a screw in ND x10 (B&W), this was on a 50mm F1.4, 58mm filter, and to compare I held the slot-in filter against the lens.
Suffice to say, on all the shots using the slot-in on the 24 mm lens, I experienced the same 'blobs' as Lee did. I tried varying apertures, light, shooting in shade, sun behind, in front etc, regardless , the blobs appeared sometimes prominent, sometimes faint.
Here are some examples, please disregard any cast, exposure, the exposure times were guestimates, I normally fine tune exposures when shooting with a 10 stop grad to get it right.
Also, the times I took exposure readings through the filter (never an exact science) there was quite a variation between the two types.
This was the best I achieved-they are still present around the bottom of the image.
Comparison shot between screw-in and slot (on a 50mm F1.4 lens), the blob problem didn't occur, but a funny looking magenta splodge in the middle of the image did.
screw-in
slot-in
above at f22, tried similar at f11, fainter, but still there.
screw-in
slot-in
I'll let you draw your own conclusions (you usually do anyway
), but for me, it's a great pity the slot in doesn't really cut-it, it would be a lot easier in use than the screw-in, particularly as you need to take the filter off every time you want to compose, set focus, check light etc.
Once again many thanks to 68lbs for letting me test drive the slot in filter.
screw-in
slot-in
screw-in
slot-in
