Yongnuo speedlite flash
MiqsPix
Roger
I have three Yongnuo YN560 111 speedlite flashes and use them on manual setting for high speed water drop photography. I also have a Yongnuo YN600 EX-RT 11 speedlite flash which is TTL with my EOS 90D. However I want to use it on manual together with the other three but don't know if it will sync exactly when using a remote trigger. Anyone know for sure? Or do I have to try? Just trying to save time.
Thanks Chris. Interesting but I guess the only way is to test them all and see if there is any ghosting. I don't mean from ambient light but from a delay in the sync of the flash. I know that all my YN 560's have perfect sync flash to each other. The obvious principle being you should always use the same make of speedlite flashes. I'm using the same make but not the same model. And furthermore to complicate matters I'm using Hahnel remote triggers not Yongnuo. Will test and see.
