Ivan S
- Ivan
I recently purchased the 565EX but cannot get the MULTI mode to work, would you do me a favor and check yours is working as it should or MULTI means something else on this model ? as everything else like ttl and manual and power adjustments work fine and so does the output, just refuse's to strobe(it outputs whatever power is set when pressing the PILOT button), It's not a feature I really need but if it's at fault I need to get it sorted.
