Stephen Chantry
Hi Guys, new to the forum so a big Hello!!
In summary I currently have a number of Yongnuo YN568ex (Nikon) flashes, one failed to turn on (although little use I will add but over a year old) so I bought a YN685 to replace. I am using a YN622N-TX to trigger latest firmware, with a YN622N receiver on the 568 and obviously the built in radio on the 685. However if I trigger both flashes from the 622N-TX (both set to same output) the 568 SIGNIFICANTLY overpowers the 685 in flash output. I did some experimenting and even half power on the 586 is the same as full power on the 685 even though that's supposed to have a slightly better flash output. In manual mode they both seem equal the issue only happens if both triggered via the 622N-TX. What's going on here? Any one else seen this issue, recognise it a specific set of kit and circumstance, but it seems the radio implementation on the 685 is duff..
Any thoughts? thanks!!!
