vRSG60
- Shaun
I've just taken delivery of a Yongnuo YN565EX flash gun to use with my D90. This unit has "multi" mode. I can set the flash power, frequency (flashes / second) and number of flashes per activation.
Can someone explain the relationship between my shutter speed (say 1 Second) and the other required settings.
Let's say i wanted 3 flashes at 1/2 power using a shutter speed of 1 second what would I need to set the frequency as? 3?
What would the frequency setting be for 3 flashes over a 2 second exposure? 1.5?
Or if the flash is on camera will it just hold the shutter open for the specific duration to suit the settings?
As I see it number of flashes divided by the frequency = shutter speed. So number of flashes/shutter speed = frequency.
So 3 flashes using a 1/160 shutter speed = 480 frequency.
Also will it work if I was to use this off camera using triggers. (Which is why I'm trying to calculate shutter speed).
