Beginner Xtar VC4H Charger
Mark65
Mark
Hi all,
I bought the above charger for the new 1.2 ni-hm eneloop battery's I got for my flash.
It only seems to charge 2 at a time in channel 1 and 2, is this normal or have I got a faulty unit?, the older version does 4, I'm hoping someone may have experience with the make.
Update on this in case anyone else has the problem.
I removed the back and pressed the circuit boards lightly and also removed the springs from the anchor points and re attached them.
It now works as it should and charges in all 4 slots, maybe it had been knocked in transit or the boards were not quite seated.
Mark
I had a VC4SL. It's a great charger with a grading function that discharges the cells and recharged them and shows the actual capacity, a storage function to charge them to the proper amount for storage. XTAR has a lot of models. I think the "SL" model may be similar as "H".
