Work in progress, 35mm DSLR scanning/copying.
MrDrizz
Mark
Taking inspiration from the classic Slide copier I designed a 35mm DSLR scanner thingy. It is still a work in progress though, currently using an old film holder from a cheap scanner.
It's designed for my particular macro lens but no reason it couldn't be adapted for other lenses.
Next step is to design a holder for the film and I will use the old scanner holder as a base.
So far proof of concept confirmed.
All 3D printed
That looks interesting, Mark. I had an AICO slide copier for a while, and the slide end of the device was very definitely designed for slides. I did try pushing a film strip through, but it was all over the place. It looks like you have something a bit more sophisticated there.
What is your light source?
I have tried a small LED and a speedlight.
I also need to add some defusion.
One of these is good for strips of negatives...
The same thing open...
There was a time when camera shop bargain bins were full of them for 50p or £1 but there are few camera shops and fewer bargain bins these days. You could try Mr Cad...
or perhaps Beverly Camera Centre...
Thank you @AndrewFlannigan for that suggestion. That would work well but I have designed my own but its still remains to be seen if it scratches a negative.
Version 2
This one uses a step up ring rather than fitting over the lens like the previous version. I also need to extend the tube section so I can get a bit more of the film sprockets.
I may also look at designing so it more universal and publish to printables.
