Jamieconverge
Hi there, i like to shoot with a single studio flash head via pc sync lead from my camera, ive also got a flashgun that can be worked in slave mode and it gets picked up by the main flash - i use this combination regularly with the flashgun as a rear/back/hair light. all works well. however occasionally(often!) ill need the flashgun in a position where it cant be 'seen' by the main flash and so is hit or miss whether it fires, so im looking for a more reliable way i can fine it.
im looking for the cheapest way i can use it, its not a flashgun id ever wamt to use off camera by itself (its an automatic one and i make do with various levels of diffussion to tone it down) so an expensive wireless trigger system would be a waste.
what would be my options? could i use cheap a ebay trigger as well as my pc sync lead, or will my camera get confused at using both hotshoe and pc sync?
thanks
thanks
