officially no, but you can remove part of the back of the lens meaning it will physically mount, but can only be used from about 12mm onwards to avoid the mirror hitting the back of the lens (lots of people have modified it for fitting a 5D)
Would have thought it easier just to buy an EF mount UWA then to balls up a lens and ruin its resale value![]()
The part removed can be easily re-attached - no EF mount lens gives 12mm sof or some people it might be worth it
Yep. The Sigma 12-24mm is compatible with full frame, where it is absolutely, postively, insanely wide.What about this one:
http://www.warehouseexpress.com/product/default.aspx?sku=13086
