What flash are you using with your Nikons on-camera?
I have two SB600 speedlights and think they are pretty good.
I have a SB-400 but looking to get a better flash for on-camera TTL work, bouncing off ceilings/walls etc. I was thinking of either a used SB-700 or new SB-500 (which would be a bit smaller and I believe is pretty easy to use).
What are you folks using for portraits, events, etc when the flash is on camera, and would you go for either of the ones I mentioned or something completely different?
Cheers :)
I use the SB-400, 500, 700 & 800. If you don't need a lot of power, the SB-500 is small, compact and very portable. A joy to use.
