amumonamission
- Sarah
Can someone tell me if Elinchrom have the same fit a lencarta for light modifiers please.
Many thanks
Many thanks
Many thanks![]()
Brill thanks for that. No point on having a mix of lencarta and elinchrom then really is there.
Do you or anyone else know what other good brands are s fit?
Thanks![]()
Most brands are S-fit, a few others Elinchrom, and a some like Profoto and Bron have their own.
It will state on the spec sheet, as it does with Lencarta...![]()
So you have Lencartas? What's wrong with more of those?
Obvious alternative is Bowens, though you'll pay a bit more.
Thanks![]()
Obviously Bowens, but also some Interfit (I think all but the cheapest ones, which are Elinchrom fit), Viewfinder, Elemental Studio-Flash, Lastolite, Lencarta, to name but a few.
Have heard a few issues with Lastolites, have heard good things about Elemental.
We use Bowens, as they're heavier duty heads than all the above and they are worth paying that little extra for in my opinion based on the fact that should anything go wrong, you can still get servicing and parts replaced decades after you bought them. This is where the cheaper brands fall over in my opinion.
That is incorrect unless you state the model..... Bowens make cheap as well as pro lights. Not all Bowens lights are heavy duty.We use Bowens, as they're heavier duty heads than all the above
I don't get that comment? Elinchrom fit cheap?!
You misread his post - he said that cheaper interfit flashes are elinchrom fit whereas the more expensive interfit flashes are s fit
