(wanted) Idiots guide to LR3 on two machines
loafer27
Paul
As title really anyone have any tips or a link to a fairly straightforward guide to setting up LR3 on a Laptop and home PC at the same time ?
If it covers storing the RAW files themselves on a separate NAS then thats even better :thumbs:
Im sure i read somewhere that Lightroom does not support storing images on a network drive. Im sure someone will be able to confirm this.
No problems with network drives. The issue is going to be making sure you only use one app at a time - especially if you hibernate the laptop with LR running and then change the catalog(ue) with the desktop...
As Andy says, you are inviting problems if you use LR3 with network file storage accessible by two machines!
I also have LR3 on PC & laptop. The PC is the "primary" LR3 installation. In my case with storage on local drive, but the files could easily be stored on an NAS, but I'd suggest it would slow LR3 down to an unacceptable level. IMO, better to store on local fast drive and back up to NAS.
I assume you use your laptop when "out and about". On your return when you want to update the "primary" installation, simply select the relevant images on the laptop and "File-Export as catalog..". Tick "Export negative files" and "Include available previews". Save the catalog (probably on your NAS?) and then in your primary LR3 installation, "File-Import from catalog".
All your develop settings, keywords, captions etc. will be imported along with the RAW files.
I hope this helps
Steve
Thanks guys :)
The idea is like you say having my home PC as the main machine for editing and the Laptop while im away or if i know ive got a quiet night at work etc.
The thinking behind using the NAS to store the raw files was that then the files would always be available to both machines rather than copying across from main to laptop and vice versa.
Perhaps its a trying to run before I can walk type thing I should concentrate on getting it all working on my main machine first.
I was hoping to set it up right first time to avoid having to change some stuff round after a few months which is what normally happens when I find out stuff thats taken me ages can be done autoamagically if u tick this box and press that button etc etc
Lightroom does not simply access the raw files. It also uses the LR Catalog to store previews and adjustments. This is why images have to be imported into Lightroom. Of course an image can simply be added to the catalog during the import process without being copied or moved. LR is not a file browser, so you can't simply browse images in folders.
Yes, I suggest you do use a single installation on your main machine first so that you can become familiar with the way lightroom works. In the meantime, if you are out and about and need to import images into your laptop installation, go ahead. You won't lose anything.
It is worth gettng your head around how LR works before going too far, but you'll find there is very little you can do that cannot be rectified subsequently. When you come to edit (develop) images, remember that LR only stores the adjustments and applies them to the raw image. It doesn't change the image at all (you can't directly edit a raw image anyway). When you want to use the edited image elsewhere, you simply export as jpg or tiff. You can reverse any adjustments any time.
If you are new to LR (or even if not), I would suggest you may consider buying Martin Evening's excellent "Photoshop Lightroom 3" book. I'm looking at mine right now and it sprouts little post-it notes which I've added when reading it away from a PC and come across little gems of information.
I hope this helps - As you can probably detect, I'm a Lightroom convert!
Steve
