Using Word 2007....a question
Box Brownie
Hi all
As above I use MS Office 2007 SBE and that includes Word 2007.
My question relates to using a label template.
Is there a setting, for checking alignment etc of the labels content, to print the template grid pattern when I do a test print of the sheet on plain paper to confirm all will indeed print within each labels area.
I have yet to find such a setting or information of 'how to do it'???
TIA for the insight etc :)
No grid that I know of - usually print on a sheet of plain paper and check that way first.
Hi @ancient_mariner and @DG Phototraining
Thanks for the replies and as you said Dave I would find it 'out there'.................I just had to vary my search criteria
  1. Basically all such templates are tables
    So, you select the whole table
  2. Then on the Home Tab
    Go to the small drop down in the "paragraph" section and click on "all borders"
  3. Print.............................:)
  4. Back at Home page CTRL Z to undo the All Borders
    Ready to move on ;)
Sorted........................for now :)
