A cloth train isn't really much good if you want pure white. It's usually not bright enough, you'll struggle.
Getting a pure white background is relatively easy because you can light it separately and basically just over expose it till it's right. You can't do that with the train as if you try to light that and over exposure it, you also over expose whatever is standing on it at the same time.
To get a white train, you need a very bright material to start with (I use regular background paper) and then either some skill with post processing, or a reflective covering for the floor, or quite likely both.
There are lots of threads about this on here, but I can tell you now there is no easy or guaranteed way, and you're not getting off to a very good start using cloth.
