Using more than one flash head
kartracer
What would I need in the way of a light stand, tilt head, and bracket(s) to use two flash head units with one brolly/softbox? Would most softboxes have a large enough opening to get two flash heads through?
Hi
to give you an idea and without typing loads check this.
Should give you a start.
And have a search for a adapter to use the two on one, you could even make the bar yourself.
Thanks, the emphasis of my question was on what tilt head? I'd need to use two or three flash units. OK, now Googling Manfrotto - then to find a cheap Chinese knock-off!
I found this on Canon.
Or try THIS
What are you trying to over power?
No problems just an option if required.
