Using as external flash + christenings
chalky87
Pete
Hi Guys,
Have a quick question for you lot.
I'm chuffed that I've been asked to be the photographer for a christening for 2 close friends of mine (especially chuffed as I still consider myself as very inexperienced and amateurish).
Of course I agreed but my first thought was I wanted to get natural and personal photos of the little one and her folks as well as group shots of everyone celebrating. With this in mind I don't want to shove a flash in a younguns face.
I've bought myself the sb400 speed gun and diffuser for my nikon d5100. However I have no idea how to use it properly. I've heard bouncing he light mentioned, when should I do this? He's anyone got any advice about using an external flash and getting some great, usable shots at a christening.
Cheers in advance
that nikon guy has some good tutorials on youtube, and micheal ziebal?
do you mean a stofen?
7dayshop do a clone of the gary fong thing if you want to buy more gear btw
Bouncing flash requires a suitable surface, rare in churches. So you either have to take your own surface*, take your chances, or shoot in available light. I'd mix it up, do you have a fast lens for available light shots?
* a reflector held by an assistant does wonders.
they might not even allow flash in a church. I would think about fast prime like 50mm f/1.4
Reflector is only good for posed shots
Keep it simple.
Forget the flash, crank up the ISO a notch and even a 50mm f1.8 will probably do.
If it's new to you remove the worry of flash etc and just shoot.
Just my opinion.
Be mindful that the SB400 only bounces vertically so with camera in horizontal position you'll have to bounce off a surface above you, and with the camera on the vertical (i.e. on the side) you'll need a surface to your left or right to bounce off. The former poses problems if the surface (ceiling) is too high, as you'll lose power. If you're bouncing off a wall then make sure you don't have obstructions in the way that will cause shadows and ruin the bounce :)
