USB external Hard Drive problem, MAC Powerbook
atp_image
Adam
OK, I have just received a new 250gb external HDD for my birthday so i can upload all my photos onto it from my laptop.
Its one of those new USB2 ones and i am using a 3 year old PowerBook G4 17" with all the fruit. Problem is the external HD is not getting enough current to power up from my USB port.
I purchased a FW cable and that had no impact. I purchased a IOGEAR USB booster cable and it too had no impact (despite packaging promises)
The HDD just ticks over with a pulsating glow on the LED.
Rumour has it that my laptop does not send out enough current from the USB ports hence why the booster cable is needed, or so i was led to believe.
How can i get this puppy to work ? :shrug:
help :help:
Easiest way will be to buy a powered usb hub and do it that way.
Although I thought at least 1 of the port would be powerful enough...
I know not all are powered but I thought one would be.
Shutterman
Did it not come with a power supply? if not check for a socket on the drive to see if you can add one.
USB1 delivers a lot less power than USB2. What does your MacBook have? You could get a powered hub or a twin cable. All my USB drives have a cable like a Y that attaches to two USB ports to deliver the correct amount of power to drive the drive.
You are a LEGEND !
Thank you, it worked using that 'y' method.
