Studio488commercial
- No
5dmk4 or EOSr with EF adapter ? anyone got both ? or changed from one to the another ? for us in the studio
I've got both. The EF adapters work perfectly on the R.
If I'm using manual focus I really like the focus peaking on the R. It's also lighter and more compact, but I would say the 5d4 is a better overall camera and more reliable for shooting action. I'm not sure about for studio use, but I'm more inclined to rely on my 5d4.
Edit: also to add if you use back button focusing I think that it's slightly more awkward on the R
Sorry, I know this off topic.I have the same dilemma.
The plan was always a 5D4 as soon as the dust settled on our recent house move. A substantial upgrade on the 5D2, particularly AF, a familiar control layout with same CF cards etc. Easy choice.
Then the EOS-R came along. Initially disappointed, but now the new firmware v1.4 appears to have transformed eye-AF performance and I want that. An articulating screen would also be handy, particularly for tripod work that I do a lot of and almost always in live view. Then there's the clincher...
I would be using adapted EF lenses and Canon makes an adapter with a variable ND filter built in https://www.cliftoncameras.co.uk/Canon-Dropin-Variable-ND-Filter-for-EFEOS-R-Adapter I do a lot of work with flash outdoors and using ND filters is the best way (for me) of keeping the shutter speed within x-sync when shooting with low f/numbers in daylight. Compared to high-speed sync, the ND method effectively increases flash output by at least one stop and in bright sun you usually need all the flash power you can muster. In other words, a Godox AD400 would be putting out as much light as an 800-1000Ws head in HSS mode, maybe more. With a DSLR's optical viewfinder, you can't use more than a couple of stops ND before the viewfinder gets unusably dark and that's just not enough (3-6 stops is the ideal ND range).
Sorry, I knw this off topic.
What do you photograph that needs a high ND filter but lots of flash power? Having read a few of your (excellent) posts I know you'l have a good and valid reason, just intrigued that's all.
3-4 stops looks just a tad darker than a CPL filter. That's easy. Even 9 stops still leave a legible, but very dim view in normal daylight.
Are you doing this so that flash is the primary light source then, or do you still need to do all this just for fill flash in certain situations?Outdoor portraiture in bright sun with low f/number for shallow DoF.
Using flash outdoors is very different to a darkened studio where you can do most things with modest power and x-sync is never a problem. And if you do need more power in a situation where there's no significant ambient light, then bumping the ISO is effectively the same as doubling the flash power with every stop.
Outdoors, the ambient light level sets your baseline and sunlight is very bright. To beat that with flash needs at least 400Ws (that's a handful of speedlights minimum) and preferably much more for a softbox at a decent distance. Then to shoot at say f/1.4 on a bright day you simply run out of fast enough shutter speeds for correct exposure, so even without flash and at base ISO, a couple of stops ND filter is needed just to get a usable shutter speed. Then when adding flash into the equation, the shutter speed needs to be pulled down much further to 1/200sec or so, requiring a much darker ND filter (maybe six stops-ish).
ND filters over about three stops are simply impractical IMHO when using a DSLR's optical viewfinder. I have a four stops ND but it's too dark and I never use it as I just can't properly see what's going on. It's usable for basic framing but hopeless for portraits when you're trying to capture subtle gestures and fleeting expressions.
Of course, high-speed sync is the obvious answer but that is inherently very inefficient and most of the light is simply wasted - you lose a couple of stops of effective flash output just by switching it on.
"Just a tad darker...?" I've never tested a polariser darker than 1.9 stops and most are around 1.5-1.7 stops, with the lighter-toned variety only 1.2 stops.
You have obviously never tried shooting a live, moving subject with a dark ND filter on a DSLR. They are not landscapes with a tripod. It's not fun.
I am not debating fun factor. In a studio it certainly wouldn't be fun. Outdoors I barely notice nd8 filter when I use it. It may not do anything good for af tracking fast subject but it will still function
If it were me I would wait for the higher res mirrorless version, especially for studio work.
If I had to buy now I would opt for the R (I have an R and moved from a 77d but have used 5d's on various jobs).
Once you get used to the R, its handling and controls it is hard to go back to a dslr! Eye tracking is a god send!!
If the EOS-R with that pricey little vari-ND filter built in to the adapter works as well as I hope, I'll be very happy.
The 'R MkII' will surely be better, but it'll be many months yet before it actually becomes available and it'll be way more expensive. The current R has plenty of pixels for me and just one card slot hasn't let me down yet![]()
The current R is doing everything I need it to do, I am very happy with it!
You very well may be. I'm just saying for people like me on the fence it makes total sense waiting a few months for a more mature model. There is really nothing that my mk3 can't do, just it can be done a little bit better, and it's getting worn out.
Just wondering what issues you think you might get with a card that you are scanning for - viruses? I've never had any issues with any card. I format them in camera after each use. I have heard of cards failing, but I didn't know you could scan them?I have invested in the sony tough sd card, which gets scanned for any potential issues every time i put it in the mac, hopefully minimising any problems I may get!
T
