realspeed
- Bazza
- No
OK what is a TSA padlock if you don't know.
It is a specially designed number combination padlock which can be opened via a key by customs officials if you forget the number code
This is what it looks like at least on my camera bag but they are all the same.
Mine came without any instructions and a key number with 810 programed in. Damn I thought it don't work.
Tried every number in turned by dialing down from 999 still didn't work. So how the hell do you unlock it???
eventually found out the setting was 000 ,obvious now I found out, so the padlock was open.
So how do I use it and lock the camera case, again more head scratching. no good just putting the case pull tags into the lock as shown
is not locked let alone with your dedicated number input.
More head scratching, nearly bald by this time. Had another close look and right underneath is a very very small push button
that is it on the right of the wheels the small round thing.
so you push that in- set your number and squeeze the plunger on the side which releases that small button. Your own number is then programed in. then you forget the number you programmed in
of course there is nothing to stop a thief taking the whole bag but it does stop the casual thief from rifling the bag for the contents
This is the case in question
Manfrotto MB PL -RL-H55 Of course the layout card that comes with it is useless for my gear so had to reworl the layout as shown above
Biggest problem getting what i wanted in it
managed a Nikon D810
Nikon 50 mm f1.4
Nikon 24-70mm f2.8
Nikon 70-200mm f2.8
Nikon sb900 flashgun
Panasonic camcorder
tabletop tripod
duel battery charger
batteries and othe bits and pieces.
Far too heavy to carry for long hence getting one with wheels (weight 11.3KG)
How i took last photo with a Nikon D300 and a Nikon 12-24 f14dx lens with a manfrotto tripod and a led light
Nikon 50 mm f1.4
Nikon 24-70mm f2.8
Nikon 70-200mm f2.8
Panasonic camcorder
tabletop tripod
