Hanley
- Paul
- No
I'm sure this has been talked about so many times, but I'm looking at an alternative to Lightroom again.
This time it isn't about the subscription, although cancelling that would be nice, I've just been so unhappy with how LR processes the files from my Canon R5 and R6, I bought the Color Fidelity profile which has helped but I'm still disappointed.
It started yesterday when I did a test, I had 3 RAW files from my R5, fed each one through Canon DPP4, Lightroom and DxO PureRaw, to see how each would look.
I thought the output from Canon DPP was the best, you'd expect this though right, they know better than anyone how to interpret their own RAW data. But it's a cumbersome addition to your workflow.
Process in DPP
Export to 16-bit TIFF (which generates a 200MB+ file)
Then import the TIFF into Lightroom
Process, tag etc as normal
Now the resulting image looks much better doing it this way but I can't see it as a long term workflow.
So the difference between DPP and DxO PureRaw wasn't a lot so I looked at their PhotoLab software, downloaded a 30 day free trial, and that contains PureRaw.
I like the interface, different to LR but I think I could get used to it.
I just wanted to know if anyone else has made the switch from Lightroom to DxoPhotoLab and what your thoughts were?
Couple of things I need to try and work out:
I have a LR plugin which helps generate keywords, I find this useful for stock images. I can't see any similar plugin for PL.
I can send an image direct from Lightroom, into Affinity Photo or Topaz DeNoise, work on it and then it come back into LR, can you do this in PL?
Process in DPP
