Tripod repairs
Why not just Araldite the centre column in the down position, more stable that way and from the specs still gives you a 4ft 2in height.
My tripod doesn't have a centre column and never used it on ones I have owned that did.
Yeah that's a good idea, it still gives me more than enough height without central column. Cheers for the tip!
If you do go with that idea perhaps cut a good part of the centre column off, might as well save a bit of weight and make it easier to get down low if needed.
